ir c5185 scan question
  • pontiac
    • 420
    How do you set PDF as default when scanning?. thanks
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: ir c5185 scan question
    That's user guide stuff amigo.......If the customer is missing the user guides - Download and Read the free copier sending and facsimile guide from the Canon download site. If memory serves me those settings are under Add. functions>Communication Settings>Common Settings>Edit standard send settings.
    • teckat
      • 16083
      1.Additional Functions
      2.Communication Settings
      3. TX Settings (Under Common Settings, Left side of panel)
      4. Scroll to the screen displaying "Edit Standard Send Settings"
      5.Select from the File Format menu the desired setting
      6.Press OK
      7. Press the reset button twice.
      • pontiac
        • 420
        Thanks a bunch.
