PS3 -or- PCL6 for IR 6000I ?
  • yazan
    • Feb 2011
    • 15
    hello , please what to choose for my Ir - 6000i , iam printing big documents including text and images \ graphics
    and is it about language ? these documents is arabic / english .
    so what is the better ? ps3 or pcl6 ? and what is the deffrent ?
    thank you tech's for any help and sugestions .
  • gensys
    • Jan 2011
    • 323
    Re: PS3 -or- PCL6 for IR 6000I ?
    there's no difference at all.
    The Road will be Mastered by >>> the Going...
    • DAG COPIERS & COMPUTERS
      • Oct 2010
      • 860
      Technically, the pcl6 superseded the pcl5e. The pcl6 driver is a good general purpose text/ graphics driver.
      It is ideal for spread sheets, word processing and database print outs. It features superior graphics, handling, but is slower than its predecessor the pcl5e.
      The Adobe postscript ps3 driver, is generally superior to all, but it requires a postscript compatible printer, it can also be a little more complex to install. The choice is yours.
      • charm5496
        • 2387
        PCL
        Printer Control Language or PCL is a common printing language used widely by many different printer manufacturers. PCL is supported by many different Operating Systems which allows for the same printer to work in many different environments. PCL is device dependent. This means that the drivers for this language utilize the printer hardware for creating some of the printed data, usually graphics data such as fill areas, underlines or fonts. This allows the computer to process the print job quickly and efficiently. The printer is then responsible to complete the creation and processing of page data. Individual printers may perform these tasks differently giving you a slightly different output.
        Pros:
        •Fast print processing.
        •Widely supported in many different Operating System platforms.
        Cons:
        •The same print job on two different printers may vary slightly.
        •Quality of graphics is dependent on the print device.
        •Not supported in most Macintosh environments
        Postscript:
        Postscript language or PS is a common printing language also used widely by many different printer manufacturer. It is used heavily in Macintosh platforms and for graphic applications in several platforms. Unlike PCL, Postscript is device independent. This means that the Postscript language creates all of the print data and does not rely on the printer for print data. This allow the output to be consistent when printed on more than one type of printer or print device. Specifically, the graphic objects will be consistent and in some cases of higher quality than PCL.
        Pros:
        •Graphical objects are often more detailed
        •The same print file should print identically on two or more different print devices. (This most beneficial when used for printing drafts on one printer then sending out to a printing company for production)
        Cons:
        •Print processing can be slow
        •Not found in as many platforms as PCL
        •Print file and memory requirements are larger.
