sticker in imagepress c1
  • DANIELCANON
    • Jun 2011
    • 187
    cual es la mejor opcion para enviar el papel stiker adesivo?
    heavy2 o labels.
  • teckat
    • 16083
    Re: sticker in imagepress c1
    heavy2 o labels.
    If you are making prints on labels, transparencies, or nonstandard paper size stock,
    load the paper stock into the stack bypass.
    Making Prints Using the Stack Bypass
    When printing on special types of paper, such as heavy paper or transparencies, be sure to correctly set the paper type, especially if you are using heavy paper.
    Depending on the type of heavy paper you want to load, if you load multiple sheets of heavy paper into the stack bypass, a paper jam may occur. In this case, load only one sheet of heavy paper at a time.
    If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
    Paper Drawers
    Do not load the following types of paper into the paper drawers. Doing so may cause a
    paper jam.
    - Severely curled or wrinkled paper
    - Thin straw paper
    - Heavy 5 paper 110 to 142 lb index (210 to 256 g/m2))
    - Paper which has been printed on using a thermal transfer printer (Do not print on the reverse side of this paper either.)
    - Coated paper
    • charm5496
      • 2387
      ORIGINAL MESSAGE: is which the best option to send the Stik adessive role?
      heavy2 or labels.
      Hopefully you are not wanting to run roll material through this machine. It does not support it.
      Second I would never run silk stock through the copier either as it has a tendency to cause quality issues and shorten part life in the machine.
      • DANIELCANON
        • Jun 2011
        • 187
        ok, gracias a todos
        • charm5496
          • 2387
          De nada
