C5180 Gradation Printout
  • Dave Braman
    • Mar 2011
    • 16
    My C5180 is printing blurry copies. The Auto Gradation sheet is printing out Blurry?
    Did an auto CCD Adjust in service mode and Level 2 in NG!
    Any thoughts?
    Dave Braman
  • teckat
    • 16083
    Re: C5180 Gradation Printout
    Any thoughts?
    Dave Braman
    make sure your paper cassettes are ok/ remove paper> pull out tray> shake upside-down> see if small gears fall out/
    next>remove and clean or replace ITB sheet
    next read>>iRC5180_Color_Shift_Prevention _&_Correction.pdf
    did u check your Test prints>> PG 6 GRID/ AND PG 10 PATTERN
    pg6 displays issue direction
    which direction is the issue>>> print out a PG6
    • Dave Braman
      • Mar 2011
      • 16
      Thank You! The displacement is in the Main Scanning Direction.
      I will continue. Thanks for your help,
      Dave
