Having issues with an IRC4080 E-000008-0001. Replaced fixing assembly, cleared counter, cleared error, updated system software and still having the same error. Any help would be appreciated.
Tags: None
Re: IRC4080 E-000008-0001
where did u purchase this unit ??
did u inspect unit before installing it ??
did u perform this after replacement --
Copier>Function>Fixing> FX-UHP-S and FX-LHP-S.to set belt positions
Check the following:
1) Clear Copier>Counter>Drbl-1>FX-BLT-U
2) Set Level 2>Copier>Option>Body>FXMSG-SW to 0
If still having problems, try doing a DCON clear. In this case, the DCON clear resolved the E008 code.
make sure u have P PRINT settings before u try DCON clear ???
After clearing DCON, re-input all of the DCON door specifications and check the values for Copier>Display>Fixing>FX-UHP and FX-LHP in service mode. If the values = 0, execute Copier>Function>Fixing> FX-UHP-S and FX-LHP-S.
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
