about canon ir 2018
  • raztech
    • Dec 2008
    • 88
    about canon ir 2018
    we have dificulties to print by network on this machine...every time we send copy to print ..we get error ...
    and no copy ....
  • Iommanxman
    • Aug 2009
    • 180
    Re: about canon ir 2018
    Does this happen from all workstations?
    Is the printer configured through a print server or are the drivers installed locally on the workstations?
    can you ping the printer with no issues?
    Have you downloaded and installed the latest driver from the Canon website?
    I think you made need to go back to basics here before troubleshooting this any further.
    • Rachid.Akli
      • Oct 2011
      • 595
      Is the machine printing with USB?
      Are you using the right driver?
      In win7, you have a driver for 32 bit version and another one for 64 bit version.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • raztech
        • Dec 2008
        • 88
        Hi rachid
        yes it is the write driver, the copieur works under the network ( RG 45) , not usb access.
        • Rachid.Akli
          • Oct 2011
          • 595
          Hi sir,
          I mean can you print using USB? If it's the case, then you have a network issue: cable, Ip address, pcb...
          I once have been in a situation where i could scan but couldn't print. A CLEAR ALL solved it.
          Rachid.
