Old copier with a lot of clicks has blank copies. Once in a while but very infrequently when you power off the copier and turn it back on you may get 1 copy. And then reverts to blank copies again. One of my techs has Swapped out the following from a working model- coronas....potential control assy....lamp regulator pcb....entire drum unit....varistor.....dc controller......dv unit.....hvt.....pot control pcb assy etc...
I,m about to take over the call and go there myself. Any ideas much appreciated. For starters im thinking xfer corona connecter grounding out or something of that nature.
