Imagepress C1 Stack Bypass
  • mailbiz
    • Jul 2025
    When placing LTR in the stack Bypass the screen for size pops up but can not make a choice if I press next it suggests I slide adjustment for paper size. No matter how I slide the bars it will not pick a size. If I do get it to go the LTR it says the size is not correct. ???
  • mark921
    • Dec 2010
    • 110
    Re: Imagepress C1 Stack Bypass
    Are you putting the paper in "letter" orientation, or "letter R" rotation?
    • mailbiz
      Either way gets me the same result.
      • charm5496
        • 2387
        you need to run your stack bypass adjustments in service mode.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Registering Paper Width Standard Value at Manual
          Feeder Tray
          imagePRESS C1 P / imagePRESS C1 / imagePRESS C1+ (Printer) / image-
          PRESS C1+
          Execute registering paper width standard value for each paper size (A4R/A4/
          A6R).
          1) Slide the manual feeder tray width guide [1] to fit for A4R.
          F-13-34
          2) Select the following service mode items:
          - COPIER > FUNCTION > CST > MF-A4R
          3) Press OK key.
          4) Write down the standard value for A4R (that was indicated on the control
          panel) on the service label.
          5) Also, make the following selections to register the paper width standard
          value for A4 and A6R:
          - COPIER > FUNCTION > CST > MF-A6R
