IR3235 E315-000D
  • Brian8506
    • 1665
    IR3235 E315-000D
    Customer has had code 3 times and claims its only when she faxes not while printing or copying. Gonna try to reseat connectors on Monday. Any help would be great.
  • teckat
    • 16083
    Re: IR3235 E315-000D
    make sure System Software version 21.06 is on the copier.
    if ok ,,try below
    make sure Multi-Cast Discovery for TCP/IP settings under Additional Functions is set to OFF.
    remove the connectors on both the RCON and Main Controller and re-seat them
    can try RCON clear> make sure the door values are re-entered .
    • Brian8506
      • 1665
      This is a wireless connection if it matters. Should multicast discovery still be off?
      • Brian8506
        • 1665
        Last time it went to error was actually copies thru df so I turned off multicast, reseated all connectors to reader and main controller. Forgot to check software version. Will do so if I have to go back.
