IR6570 error code e 804 0000
  • bineshpaul
    • Jul 2010
    • 43
    [Error Code] IR6570 error code e 804 0000
    Dear all,
    In my canon ir6570 shows error code 804 0000. pls help me, thanks in advance
    Regards
    Binesh
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: IR6570 error code e 804 0000
    • bineshpaul
      • Jul 2010
      • 43
      Originally posted by zoraldinho
      [ATTACH=CONFIG]14420[/ATTACH]
      [ATTACH=CONFIG]14421[/ATTACH]
      i checked the fan. it is working.
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        If it's not the fan you unforunately may need to replace the dc controller pcb. Also could be a problem with the wire harness.
