RDF IR3300
  • tntnutly
    • Jul 2025
    [Electrical] RDF IR3300
    all i want to ask...why when i use rdf for folio/legal always detect A3?
    can i adjust something at rdf...?
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: RDF IR3300
    Originally posted by tntnutly
    all i want to ask...why when i use rdf for folio/legal always detect A3?can i adjust something at rdf...?
    If the feeder is not detecting the width of the paper properly....the slider guides may be slightly out of alignment/position and you may need to disassemble the tray and align it properly so the VR measures width correctly. If the length is not being measured properly check both length sensors and flags for proper operation.
    DADF-H1 44.pdf
    • teckat
      • 16083
      Re: RDF IR3300
      to add on--
      DF Copies
      COPIER>OPTION>BODY>SCANSLCT
      Use it to enable or disable the original size detection mechanism for the ADF.
      • When enabled, the scan size is determined in relation to the original size.
      Settings 0: off (default), 1: on
      Caution--After making a selection, be user to turn off and then on the main power switch.
      Glass copies
      COPIER>OPTION>USER>USER
      SIZE-DET
      Use it to enable or disable the original size detection function.
      Settings 0: enable (default), 1: disable
      DADF-H1
      Tray width detection variable resistor adjustment mode
      [Operating procedure]
      1) Detach the rear cover.
      2) Set the DIP switch (DSW1) on the ADF controller PCB as illustrated and press the push switch (PSW1) to let the ADF into tray width detection variable resistor adjustment mode.
      Perform 1 for the AB system, 2 for the inch system, or either 1 or 2 for the AB/ inch system.
      3) The start of tray width detection variable resistor adjustment mode is signified by LED2 flashing slowly for the AB system or by LED4 flashing slowly for the inch system.
      4) Set the following kinds of paper in the document pickup tray, adjust the slide, and press push switch (PSW1).
      • AB system: A3 or A4
      • Inch system: 11X17 or LTR
      Pressing push switch (PSW1) will cause LED2 to flash fast for AB system or LED4 to flash fast for the inch system.
      5) Set the following kinds of paper in the document pickup tray, adjust the slide, and press the push switch (PSW1).
      • AB system: A5R
      • Inch system: LTRR or STMT
      7) When the writing of the adjustment value ends, the LED goes off, and the tray width detection variable resistor
      adjustment mode exits.
      8) When the adjustment is completed, set all ADF controller PCB DIP switch (DSW1) bits to OFF.
      • blazebusiness
        • 1250
        Re: RDF IR3300
        Originally posted by teckat
        to add on--
        DF CopiesGlass copies
        SIZE-DET
        DADF-H1[ATTACH=CONFIG]14450[/ATTACH]
        Always impressed with the detailed answers you give in your posts Kat. Good job!
