Imagerunner 2020, constant jam light...
  • Oystercopy
    • Oct 2009
    • 623
    This machine shows constant paper jams at the left of the feed unit(s). Several months back, I went out to address a paper jam issue, but ended up having to UNPLUG one of the two feed units to get it to go away. Now, its done it with the second PF unit. Any one have any idea if the paper sensors simply GO BAD on this machine?
    How about anyone having the parts diagram on this model?
    Thanks in advance,
    OC
  • teckat
    • 16083
    Re: Imagerunner 2020, constant jam light...
    Thanks in advance,
    OC
    how about jam codes ?
    delay jam ? stationary jam ??
    Jam Log is included in the Error Log.
    To print out a JAM/ERR Log do the following steps:
    Access Service mode
    hit ADDITIONAL FUNCTIONS>(*2)>then hit ADDITIONAL FUNCTIONS(*8)
    Scroll until you see "# REPORT" hit OK
    Scroll until you see "REPORT OUTPUT" hit OK
    Scroll until you see "ERROR LOG LIST" hit OK
    jams on prints & copies ??
    all paper type ??
    • Oystercopy
      • Oct 2009
      • 623
      Printing out a jam code list might be nice if the machine were RUNNING, but unable to do so if its not....
      • teckat
        • 16083
        need to remove unit & inspect/ known as get down & dirty
        also read this pdf>> GEARS_TP07.pdf
        when u power up it shows jam ?? if not u can set MF for print out log--
        • Oystercopy
          • Oct 2009
          • 623
          Yes, it shows a jam upon POWER UP.. that's what's frustrating us. I'm sorry, but I don't know what "Set MF for print log" means...
          • teckat
            • 16083
            pull out the feed unit-to inspect interior
            forget about the log for now--
            • teckat
              • 16083
              READ PDF>>>>
              iR2016-2020 Pick Up-Feed System.pdf
              • Oystercopy
                • Oct 2009
                • 623
                We've pulled out and inspected every sensor we can find; nothing is restricted. I just looked through the parts guide and many of the sensors are the same, so I'm just going to order like 3 of each and give it a shot...
