canon ir3300 jam wen making duplex
  • universaltvm
    • May 2010
    • 52
    [Jamming] canon ir3300 jam wen making duplex
    hi my canon ir 3300 giving duplex jams, wen i makes single sided copies it coming without any problem wen i makes 2sided copies 1st 2 0r 3 copies come wintout any problem after that the paper goes through the drum unit , wen it just enters to the fixing area paper folds like z shape then it jams. i have changed fixing unit ,changed sensors , feed rollers even drum and blade then also the same is occuring in same way . what should i do plzzz help me thanks in advance
  • universaltvm
    • May 2010
    • 52
    Re: canon ir3300 jam wen making duplex
    plz help mee i am in a trouble plzzz help
    • universaltvm
      • May 2010
      • 52
      o122 jam code, this sensor is replaced
      • totoro
        • 568
        Try feeding the paper through in the R direction or try 8.5 x 14 or 11 x 17 and see if it jams. If it doesn't then it is probably as Canon.Tech says bad paper.
        Totoro
        • universaltvm
          • May 2010
          • 52
          i have used both a4 ,a4r also the same thing appears , it jams between drum unit and fixing unit
          • teckat
            • 16083
            Originally posted by Canon.Tech
            What are the jam codes?
            did u inspect the flag for this sensor/
            delay jams> work your way back from this sensor
            follow a check list procedure to trace
            • eurokris
              • 120
              hi
              try to change hvt pcb or try to adjust the seperation or tranfer current.
              thanks
              • universaltvm
                • May 2010
                • 52
                i cheked all these , still the paroblem occurs inall paper size a4,a4r,a3,legal
                • linuxxpwin
                  • May 2008
                  • 205
                  Hi, I have had this problem as with a few other models such as the 3570/4570/2230/2270 and so on and I found that using a heavier paper corrected my problem, something in the way the paper curved for me in my machines was causing constant jams. I am presently using and have recommended to all my customers to use 22 or 24lb paper.
                  Try this see if it works for you.
                  • teckat
                    • 16083
                    solution is = don't duplex
                    • universaltvm
                      • May 2010
                      • 52
                      that is not a right solution for this
                      • teckat
                        • 16083
                        then follow a procedure
                        • linuxxpwin
                          • May 2008
                          • 205
                          Can you please check the duplex motor, the gear sometimes crack or break on the inner part of the gear, this sometimes makes a noise only heard when doing duplex copies.
                          • universaltvm
                            • May 2010
                            • 52
                            i will check this out
                            • universaltvm
                              • May 2010
                              • 52
                              there is no sound heared what next plz help me coustmer is asking to solve this problem soon , plz help me wahat should i do help me thanks in advance
