IR5000i FIRMWARE PROBLEM
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Hi to every body. Am working on IR5000i machine trying to install firmware.Initially,the machine was showing WAIT non stop on the screen. I acquired firmware that i have tried to install with no success.Before i configured my pc,i would get error 145 of the sst.After configuration of the pc,whenever i try to load the firmware it tends to start loading and error 92 appears and says target code did not match,check connection between the machine and the pc.I have tried using another pc but get the same error message.Am using sst 3.35E version with firmware of HDformat version0005,boot ROM of version 0725.The harddisck is samsangSV2001H.Assistance requested,thanks in advance.
