Jam with code 0111 on iR -ADV 6075when duplexing !
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    I'm back!
    I have this interesting problem: iR-ADV 6075 with code jam 0111 when duplexing.
    The defect is in the detachment of the paper transfer unit ... I've encountered working with the door open.
    Is there a way to improve the separation of paper from the drum when it concerns the second side?
    Or, have you solved in another way?
    Thank you.
  • charm5496
    • 2387
    Re: Jam with code 0111 on iR -ADV 6075when duplexing !
    adjusting this in service mode should help >>>>ADJ > HVTR >TR-L-OF1.
    this increases the seperation current
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Thanks for the information. I will try this ! ! !
      • sugumaran
        hi is the solution works... >>>>ADJ > HVTR >TR-L-OF1????
        • dan7777
          • Dec 2012
          • 680
          If that does not work for you try to put bearings in the reverse delivery unit where the bushings were. I had a school that had jamming problems and did a lot of duplexing. I put the bearings in about two years ago and have run more than a million with no more jamming problems. Also either clean the bushing in the assembly you open to the left of the fuser or replace the bushing with a bearing.
