imagepress c7000vp Drum temperature
  • alexctx
    • Dec 2010
    • 157
    I need the publication TP08 362b If Any of the Drum temperature readings are Above 38 degrees Celsius, Perform the Drum Heater
    As described in procedure Adjustment Canon. Technical Publication TP08 362b (pages 6-7)
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: imagepress c7000vp Drum temperature
    ipc7000vp-057.pdf
    • teckat
      • 16083
      Prevention of Tiger Stripes on the Image in the Developing Assembly
      ++Drum heater adjustment procedure
      imagePRESS C7000VP Series
      Products Affected: Serial Numbers Affected:
      imagePRESS C7000VP========KTL00001-KTL00802
      imagePRESS C6000VP========CWM00001-CWM00131
      imagePRESS C6000==========KTY00001-KTY00434
      • alexctx
        • Dec 2010
        • 157
        muchas gracias .
        el envia de file. que viene con . la irc1021 .funciona en mac?
