Canon IR1510 -E245
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Error Code] Canon IR1510 -E245
    Hi to all
    i have Copier ir1510 apear an err E245, i tryed to clear all the counter but nothing can any one help me!h
    thanks in advence
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • teckat
    • 16083
    Re: Canon IR1510 -E245
    Originally posted by sweet.persona
    Hi to all
    thanks in advence
    The following steps should be taken in troubleshooting an E245 code:
    • Check for a loose connection between the Main Controller and the Counter PCB during a copy run.
    • Check the screw is tight on the Counter PCB.
    • Confirm the machine has been flashed to the latest software.
    • Replacing the Main Controller will resolve the problem if the Counter PCB is working. Counter PCB must stay with copier. The Main Controller with E245 may not be bad but needs to be sent into Nationwide/Hytech to have the counters zeroed out.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      i have replaced New counter pcb but Nothing! there is an idea!
      DAMENE ABDEL AZIZ
      DJELFA
      • teckat
        • 16083
        where did u get this Counter pcb. / ??
        Replaced Counter Memory PCB & did u Clear E355
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          thanks friend teckat now i understand
          DAMENE ABDEL AZIZ
          DJELFA
