Thick paper for Canon iRC5185
  • stratis
    Hello guys,
    Does anybody know untill which weight can Canon iRC5185, 4580 or 4080 handle from bypass?
    Thanks in advance.
  • nghialuuvn
    • Jan 2008
    • 67
    Hi Stratis,
    It can handle heavy paper up to 200g/m2
    • stratis
      Thank you for the answer.
      I have a problem if you can help me. I now own a iRC3200 and I can print on 300gr thick card stock in a good quality. The problem is that the cost per copy is double than the new canon machines. So I decided to buy a new canon machine. The thing is that the new canon cannot print on extra heavy paper, so I try to find another machine to do my job. I found that the new Konica machines C451, C550 etc do handle 300gr officially. But I am not sure for the print quality of these machines.
      If you have something about please help.
      Thanks in advance
      • Canuck
        Tech Specialist
        • 1713
        Any of the Canon IRC series(3200,4080,5180) have a maximum paper weight of 263 gms or caliper(thickness) of 10.5 pt. You can try to run 12pt. but if you have problems Canon wont support it...these are business color machines. The only machine that Canon will support to run 12pt. is the V7000
