IR8500 Pickup Motor
  • mezerwi
    • Aug 2010
    • 58
    [Jamming] IR8500 Pickup Motor
    Hi,
    As attached, image of the worn out gear. May I know if i need to change whole set, only this gear?
    Motor # = FH6-1871
  • vigour
    • Aug 2010
    • 1038
    Re: IR8500 Pickup Motor
    you can't get that gear that gear by itself, it comes with the motor
    • mezerwi
      • Aug 2010
      • 58
      Ok noted, how much would normally it cost? Thanks
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Two houndred bucks.
        • mezerwi
          • Aug 2010
          • 58
          Originally posted by zoraldinho
          Two houndred bucks.
          OK noted, thanks.
