Canon iIRC4080 fuser parts info needed
  • jim salter
    • Aug 2025
    I plan to buy a IRC 4080. Can you tell me where to buy the upper fuser kit and/or the lower roller. How many copies do they usually last ?
    Thanks Jim
  • charm5496
    • 2387
    Re: Canon iIRC4080 fuser parts info needed
    the fuser can only be replaced as a single unit and is very expensive. It can last anywhere from 100K to 800K depending on your volume and what stock you run through the device.
    Canon imageRUNNER C4580i Fuser Assemblies / Units
    • teckat
      • 16083
      Thanks Jim
      $1,199.00-
      FREE GROUND SHIPPING! Factory Sealed New Part!
      also check these companies below
      Canon FM33778000 Fuser Unit - 120 Volt Fuser Assembly, Canon FM3-3778-000 - Original (OEM)
      http://www.gottinta.com/toner-cartri...d=FM33778000-o
      or call to see for 4080
      Fusion Image Technology
      4006 E. 137th Terrace
      Grandview, MO 64030 Phone: 816.979.1000
      Fixing Assemblies, Fixing Film Units - Fusion Image Technology
      • Herrmann
        • Jan 2006
        • 792
        Official Statement from Canon is 300000, but in fact, i have seen a lot of them turning belly up between 100000 to 200000. So beware, if you are not an official Canon Dealer with the possibility to get a guarantee reward from them.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • teckat
          • 16083
          it's a toss up to remove and inspect > to order parts or not > if u are not sure part will repair issue u have to face customer with more down time>
          E007= we always order or keep on hand new or refurb units from Canon/ machine base to large not to-
          understand not all techs have that privilege of stock
          • V-P
            • Apr 2011
            • 679
            I know this is an old thread but has anyone tried to replace just the upper & lower sleeves "successfully" on these series ?
            I have seen some Chinese companies selling just the film sleeves for about 80 USD / piece. Very tempting...
            • SCREWTAPE
              East Coast Imaging
              • 3396
              belts
              You can try repairing it. But, belts are not always the issue when this unit has problems. Not worth it. Plus you don't know what those Chinese people are selling. Those belt are generic.
              • teckat
                • 16083
                u need to remember this> it's the inside deterioration coating of metal roller that bunches /rips up top sleeve from un-coated thermostat face that causes belt to tear/
                also u have gear issues>sensor issues from heat>to inspect/change>pressure adjustment
                lost time & performance =lost money
                • V-P
                  • Apr 2011
                  • 679
                  Thnx Guys !
                  Didn't know about the deterioration of the coating material of the roller. I thought it was only the belt which tears up.
                  Thnx
                  V-P
