ir7105 white screen and then black
  • alexctx
    • Dec 2010
    • 157
    iR7105. was working normal. from one moment to another. the screen went on. white and then. black. turn off and turned on. sige black screen.and discard memory, hard disk, screen.them has occurred. a. past. in the field?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir7105 white screen and then black
    Any errors in the past.E315 maybe?
    • alexctx
      • Dec 2010
      • 157
      not just any jam
      • Herrmann
        • Jan 2006
        • 792
        Does the image look like this?
        If so, have a look at the backside of your dc controller, does it look like this:
        if the c slots are empty, go to a radio shack, buy 3 smd capacitors 0,01mF and solder them in
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • alexctx
          • Dec 2010
          • 157
          no. . as. other. estubiera. bad memory.
          • Herrmann
            • Jan 2006
            • 792
            maybe i misunderstood you, did you mean the operation panel went black?
            • alexctx
              • Dec 2010
              • 157
              or off
