ir c5185 adf problem
+ More Options
Posts
  • pontiac
    • 420
    Have a copier that shows a 0094 jam. Copier has to be turned off and on just to reset adf. I replaced the adf with another one and the same jam. Pick up rollers don't even engage when copy button is pressed. No error codes. Any sugestions thanks.
  • HELIO240
    • Jan 2011
    • 137
    Re: ir c5185 adf problem
    Ol, I had this same problem in another DADF s1 canon IR5055 and the solution I found was to replace the sensor PCB4 see the drawing, it was burned to the LEDs. In my case resolved. Then you must enter the service mode and run the set of sensors dadf.ok I have helped.
    • teckat
      • 16083
      u tried another DF = same issue/ check Reader Controller PCB
      • pontiac
        • 420
        Thanks for replys. I will post results when done. Thanks again
