Black background on iR-ADV 6075
  • Ingranaggio_rotto
    • Oct 2010
    • 274
    Hi!
    It 's a problem that I had already exposed but have not been able to solve ..
    I have an iR ADV 6075, whit black background, with the potential Control active..
    If switched off the potential control, and set the BIAS control I can get a good quality ...
    So, I replaced:
    Primary, Developing unit, ozone filter, Potential Control PCB, pre-transfer unit, reset of the DC, but .... nothing!
    I disconnected the sensors of environmental control, but nothing!
    The system installed is the release 41.xx. ..
    Tips?
    Thank you!
  • seniortech
    • Dec 2007
    • 180
    Re: Black background on iR-ADV 6075
    Make sure that the dev bias contacts are making good contact, slightly bent the copper contacts on the top of the dev unit upwards and the copper contacts inside the machine slightly downwards...
    • Ingranaggio_rotto
      • Oct 2010
      • 274
      Those contacts I've checked! All right!
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 4999
        Post a picture please.
        • Herrmann
          • Jan 2006
          • 792
          Check if the dust proof glass and laser mirrors are clean, in contrast to most other mashines, the new canon are "black writers", means a dirty dust proof glass or weak laser does not result in fade or white pictures, its getting dark.
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • Rachid.Akli
            • Oct 2011
            • 595
            Hi to all,
            Please send a test, the VLm and Vdm values.
            I confirm what wrote Herrmann: The dark drum surface (Laser off) receives toner.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • vigour
              • Aug 2010
              • 1038
              These units are strange.
              I had background after a jam, while doing test prints PG4.
              Background disappeared immediately after that set
              • Ingranaggio_rotto
                • Oct 2010
                • 274
                Hello to all ....
                So, I cleaned the drum with cerium oxide and I cleaned the laser unit (which was not even dirty) ...
                I will do the tests required and put a post with the photo of the problem ...
                Thanks to all!
