lumps of toner black, on copies / prints on iR-ADV C 5051
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Another problem:
    lumps of black toner on the iR ADV C5051 ...
    I replaced both the black drum and the Developing the unit, but after a while (5,000 copies / prints approximately) the problem has reappeared ...
    Have you ever?
    Thank !
  • teckat
    • 16083
    Re: lumps of toner black, on copies / prints on iR-ADV C 5051
    Originally posted by Ingranaggio_rotto
    Another problem:
    Have you ever?
    Thank !
    post a copy of issue
    where are buying toner ?? OEM ??
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      The toner is original, Canon...
      Then I will post a copy.
      • northernlife
        • Sep 2011
        • 847
        Fuser causes this issue. There's a sep blade in the fuser that causes this issue. Make sure you update the firmware if you still have a v1 5051 as the firmware fixes a lot of the fuser related issues I've been seeing (groaning, 0113's) Only thing that sucks is the film alone is near 600 bucks.
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          I'll check....
          But I ask me: why only with toner black and not with toner color ?
          • northernlife
            • Sep 2011
            • 847
            I wish I could answer that. Everytime I take them apart it's just black gunk on the sep guide. The drums for BK are different than the colours so perhaps that has to do with it. But I can say that I have successfully gotten rid of those streaks with the fuser/firmware update (I love CDS)
            I'll check....
            • Ingranaggio_rotto
              • Oct 2010
              • 275
              I found the cause!
              Too black toner in the developing unit ! Removing the toner bottle and discharging the group of black (PG Type 5 at 255 to 100 sheets of A3 size), everything is back to normal!
              Thank for the helps !
              • Simons
                • Jun 2008
                • 490
                Too much Black toner in the dev unit? So are you saying this was a overtoning problem. Very dense black with some shaking off in the fuser? Really? As in ifailir6870fuus?
                Where is our example attachment? I would like to see it!
                • Ingranaggio_rotto
                  • Oct 2010
                  • 275
                  Hi ....
                  This printer has something like 890,000.0 copies / prints.
                  And in total, just 165.000 color ...
                  He works extensively with the b / w ....
                  And for the last time he worked exclusively with the black group .....
                  Causing a overtoner black ...
                  Unfortunately I no longer have an example to show!
                  • teckat
                    • 16083
                    heavy volume will usually not cause overtone on these new type iR's
                    just tell your customer to do the prescribed auto gradation procedures daily
                    • Ingranaggio_rotto
                      • Oct 2010
                      • 275
                      The auto gradation procedure It 's something that the customer appears to be just a waste of time... .
                      However I would add that the printer had a quality not very good, despite the 4 drums had a life relatively new (4,000 copies / prints around).
                      So I had this idea: RAM clear DCcon ...
                      I ONLY rewrite the table values ​​placed on the front door ..
                      Running INIT ITB, AT-IMG-X, Autogradation, and quality has definitely changed for the better!
                      Black is back .. black (not saturated, because even after all those type 5 in very high density, the group is discharged!)
                      Problem solved!
                      • niyaskarimba
                        • Sep 2014
                        • 110
                        Originally posted by teckat;27879
                        [B
                        heavy volume will usually not cause overtone on these new type iR's[/B]
                        i have the similar problem...when we are changing the toner it starts,but we are using OEM TONER(GPR-30/C-EXV-28)
                        • niyaskarimba
                          • Sep 2014
                          • 110
                          [QUOTE=niyaskarimba;497351]i have the similar problem...when we are changing the toner it starts,but we are using OEM TONER(GPR-30/C-EXV-28)[/QUO
                          Please suggest
                          • niyaskarimba
                            • Sep 2014
                            • 110
                            [ATTACH=CONFIG]14719[/ATTACH]
                            [QUOTE=niyaskarimba;497352][QUOTE=niyaskarimba;497351]i have the similar problem...when we are changing the toner it starts,but we are using OEM TONER(GPR-30/C-EXV-28)[/QUO
                            Please check the attachment and suggest
                            • teckat
                              • 16083
                              [QUOTE=niyaskarimba;497354][QUOTE=niyaskarimba;497352]
                              is this a Print or Copy of original from Glass/Feeder
                              repeating image every 94mm.
                              Perform a forced drum replacement in service mode (Level 1 > Copier > Function > DPC > DRMRSETY, DRMRSETM, DRMRSETC,DRMRSETK). Then perform a complete auto gradation.
                              is this issue on BLACK ONLY ??
                              do u see howfaint image transfer from previous same copy is transferred to next copy
                              have u checked ITB assembly & Black Drum ??
