iPad and iR-ADVC 2020 i
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi !
    My client wants to print with his iPad with ADVC-iR 2020th ...
    When the device searches for the printer on the network via Wifi with AirPrint protocol, can not find it ....
    The printer has the license PS ....
    It should be enabled or something needs some license?
    Thank !
    • 16083
    Re: iPad and iR-ADVC 2020 i
    Originally posted by Ingranaggio_rotto
    Hi !
    Thank !
    Wireless LAN Board-B2 in Printer ??
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Therefore, the printer is networked with a RJ 45. Then there is an access point through which you connect to the wi fi devices with the wired network.
        • 16083
        Network Specifications
        For ordinary use, the wireless LAN board communicates with only access points.
        The wireless LAN board communicates with only one access point (Infrastructure mode).
        Adhoc Mode communication not via access points is available in the case of issue occurrence.
        One wireless LAN board can be used for one host machine. More than one wireless LAN
        board cannot be used in one host machine.
        IP address is set for the LAN connector of the host machine and the wireless LAN board
        respectively.
        Communication to the access point that conforms to 5GHz band IEEE802.11a is unavailable.
        Important
        The Wireless LAN Board-B1 to be sold in other areas than USA cannot be used in the area where the USA regulation 'FCC (Federal Communications Commission)' is applied.
        Confirming the Wireless LAN Channels
        The wireless channels you can use with the Wireless LAN Board are fixed for the country/ region it is used in. When using the Wireless LAN Board in the U.S.A., channels 1 to 11 can be used, and the region is displayed as 'US'. In the UK and other countries/regions, channels 1 to 13 can be used, and the region is displayed as 'JP, AT'.
        1. Press [WLAN Card Information] on the Extension Card Settings screen.
        Settings/Registration > Preferences > External Interface > Extension Card Settings
        Wireless LAN > WLAN Card Information > Region Code
        2. Confirm the code displayed under [Region Code].
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          Thank for the help !
          • Ingranaggio_rotto
            • Oct 2010
            • 275
            I forgot: but Airprint is a communication protocol? (such as Appletalk?)
