iR C3220 E000020-03b0
  • Smartmind
    • Aug 2011
    • 61
    [Error Code] iR C3220 E000020-03b0
    This error code (E000020-03b0) refer to Cyan drum life, i did replace a new drum, the machine star printing ok but ofter 13 color prints the same error shows up again, what i should do to fix it?
    Thanks for helping!
  • ikon01
    • Apr 2011
    • 53
    Re: iR C3220 E000020-03b0
    Thanks for helping!
    have you cleaned the salt sensors? your itb may be worn.
    • Smartmind
      • Aug 2011
      • 61
      I did replace the Salt sensor, that fix the problem, but now the magenta drum is making red lines on color prints i did change it by another used but good conditions drum, now machine take forever warming up, never get ready to print, i already check the fixing unit sensor everything looks ok, any suggestion will be good. thanks.
