Exchange HD in Canon IR8500
  • chrisban35
    • Jan 2011
    • 199
    A little help guys,
    I haven't done a Canon IR8500 HD exchange before and I'm already out in the field without the manual. I need to visit a client today and I have to replace the Hard Drive. Can someone tell me if the EXACT HD has to be used, or can I also use a 40GB HD as long as it's IDE and 4,500rpm?? I have two 4,500RPM high heat HD's in the van but I need to make sure that 40GB's will still work in the IR8500. They're both formatted in FAT32 and ready, but need to ensure these will work, otherwise will have to find one.
    Secondly, does the system self load the programming, or does it need to be pre-loaded on the HD? Thanks in advance for any help. Any steps or tricky procedures that need to be followed, please post as well. Thanks...
  • teckat
    • 16083
    Re: Exchange HD in Canon IR8500
    iR85P-105-7200-8500/ u can use these HD's if found online/ u also need the SST (Canon Service Support Tool) to load the 8500 Firmware into/ HD must be formated inside printer using the 8500 HDFormat.ift file
    orig. Canon part #WM2-5222-020
    HDWN 'HDS728040PLAT20
    HDWN 'FUJITSU MPC3032AT
    HDWN 'FUJITSU MPD3043AT
    HDWN 'FUJITSU MPE3064AT
    HDWN 'QUANTUM FIREBALL CX6.4A
    HDWN 'QUANTUM FIREBALLlct10 05
    HDWN 'QUANTUM FIREBALLlct08 04
    HDWN 'QUANTUM FIREBALLlct15 07
    HDWN 'FUJITSU MPF3102AT
    HDWN 'TOSHIBA MK6014MAP
    HDWN 'TOSHIBA MK6015MAP
    HDWN 'IBM-DJSA-205
    HDWN 'IBM-DARA-206000
    HDWN 'FUJITSU MHK2060AT
    HDWN 'ST34311A
    HDWN 'ST34313A
    HDWN 'ST310211A
    HDWN 'FUJITSU MPG3102AT E
    HDWN 'QUANTUM FIREBALLlct20 10
    HDWN 'TOSHIBA MK1016GAP
    HDWN 'IBM-DJSA-210
    HDWN 'MAXTOR 4K020H1
    HDWN 'Maxtor 2B020H1
    HDWN 'SAMSUNG SV2001H
    HDWN 'IC35L020AVER07-0
    HDWN 'WDC WD300AB-00BVA0
    HDWN 'Maxtor 2F030J0
    HDWN 'ExcelStor Technology J120
    HDWN 'SAMSUNG SV0211H
    HDWN 'ST340015A
    HDWN 'SAMSUNG SV0221N
    HDWN 'SAMSUNG SV0411N
    HDWN 'HDS722540VLAT20
    HDWN 'ExcelStor Technology J640
    HDWN 'Maxtor 2F040L0
    HDWN 'SAMSUNG SP0411N
    HDWN 'WDC WD400BB-22HEA0
    HDWN 'WDC WD400BB-22JHC0
    HDWN 'ST340014A
    HDWN 'WDC WD800BB-22JHC0
    HDWN 'Hitachi HDS721680PLAT80
