Light prints from AS 400
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi to all....
    I will illustrate this problem:
    I have a Canon iR ADVC-5030 when printing only from ambient AS 400 makes clear ...
    From other applications (pdf files, word ...) the quality is right, but from AS 400 no!
    I tried to set the drive has changed the charge values ​​in the printer for the black coulor, but nothing, I get no change ...
    Can you help?
    Thanks ....
  • vigour
    • Aug 2010
    • 1038
    Re: Light prints from AS 400
    That is not unusual.
    It is usually possible to make font changes in the AS400 source codes.
    Canon sells a box made by IOCORP which gives full compatibility with AS400
    I-O, IO, AFP, AFP/IPDS, print server, ethernet, TCP/IP, AFP over TCP/IP, IPDS over TCP/IP, protocol converter, printer interface,IPDS on HP Printer
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Thanks for the suggestion....
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        Ciao, io faccio Konicaminolta, da poco hanno pubblicato questa guida che potrebbe aiutarti...
        1571-a11342.pdf
        ... In the minute that you're thinking of giving up, think about why you lasted so long ...
        • Ingranaggio_rotto
          • Oct 2010
          • 275
