Canon IR 5000/6000 F1 finisher jam code 1034. Delivery sensor PI3 delay jam.
  • Desert Rat
    • May 2008
    • 1089
    It will run a couple of 5 page sets then it will start jamming on every set. The first set
    goes through ok but when the paper is diverted into the buffer, the first sheet goes
    around ok and it accepts the second sheet. When the third sheet enters the rear of
    the LTR size paper crashes into the diverter fingers.
    The diverter goes back and forth smooth, the solenoid seems to be working, no binds.
    I tripped the top cover interlock and held the buffer down by hand to see if I could see
    what is causing the problem, but it ran fine, 20 sets of 5 pages.
    I cleaned all the rollers involved and stretches the springs under the cover to put
    more pressure on the buffer but none of my efforts made a difference.
    What am I missing here?
    DR
  • urangsunda
    • Nov 2011
    • 13
    Re: Canon IR 5000/6000 F1 finisher jam code 1034. Delivery sensor PI3 delay jam.
    check the sensor
    **we big family, yayrahmah ... special thank to bpk jonih/ibu**
    • Desert Rat
      • May 2008
      • 1089
      urangsunda,
      I will check the sensor on my next trip. I did look at the sensor with a light. It appeared clean.
      But I will check it on the I/O screen in service
      DR
