HI
I have problems with A3 sheet of the ir 4570 sometimes it goes out wrinkled like image attached.
someone knows the problem? the sheet goes out in the direction of the arrow (it is not jamming)
I have exchanged the fixing unit to other ir 4570 and the problem is always in the same machine .
I have removed the FC5-0693-000 2 DAMPER, FLAPPER in the right door assembly the problem is not gone.
I Hope to hear from you.
thanks a lot
thanks a lot
