imageRUNNER ADVANCE 5000 series- Measure for E020
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Measure for E020-0081/E020-010x /E020-020x due to breakage of the registration patch sensor and the shutter drive
    ass'y at the patch detection sensor
    For the machines with serial numbers earlier than that listed below, E020-0081/E020-010x/E020-020x occurred
    due to the breakage of the linkage member of the pattern read shutter drive assembly or protect shutter.
    - E020-010x: The value is higher than the upper limit for the patch of Y/M/C/Bk.
    - E020-020x: The value is lower than the lower limit for the patch of Y/M/C/Bk.
    - E020-0081: Error in ITB background light intensity
    advance 5000 series.pdf
