542-8005 Finisher S1
  • imagewalker
    • Jun 2010
    • 94
    [Error Code] 542-8005 Finisher S1
    Have a code 542-8005 on the S1 finisher on a iR3245...
    Only thing i could find was older posts on the 540-8005. I have No fuses blown and of course i have all the manuals but nothing for the Finisher S1 pretty much the same as the iR4570 S1. I got it working but i had to remove the shutter that moves up and down just above the exit rollers??????
  • teckat
    • 16083
    Re: 542-8005 Finisher S1
    If this applies> check if the optional tray is installed correctly.-- Tray must be level
    Removed and re-install if off level
    Check the wiring harness (from the finisher controller to the additional tray) if applies -
    -make sure to leave enough slack in the harness to clear the rear left corner of the finisher frame. If you do not the wiring harness will break as the tray moves up and down.
    do u hear noise in Finisher
    harness shown
    in the below figure does not have enough slack and would prevent the tray from driving to the down position.
    Fig 1 (Viewed from exit side of machine)
    Figure 2 (Viewed from right side of copier)
    • imagewalker
      • Jun 2010
      • 94
      Give that a try and let you know what i come up with.
      and yes something must be binding, i don't hear any weird noises either.
