IRC3170 Code E000070-0001 Please Help!
  • dilios
    • Jul 2011
    • 29
    [Error Code] IRC3170 Code E000070-0001 Please Help!
    After dis-assembly and cleaning the copier threw out a code in the first 2 minutes of warm up. E000070-0001. The code deals with fuser. It does not reach correct operating temperature. Please correct me if I am wrong. The fuser was replaced less than 150 copies ago. The whole copier has lass than 20K copies. Could it be a power issue? One of the connectors got loose? I just can not imagine it would be a brand new fuser. Is there a connection inside the fuser that might have gotten loose?
    Please do not bash this copier. Everyone knows it is a piece of s**t, so there is no reason to repeat it in every post.
    Any help would be greatly appreciated.
  • Brian8506
    • 1665
    Re: IRC3170 Code E000070-0001 Please Help!
    E0070 is a transfer belt issue. And sorry but I havent bashed that machine in a while. The best thing that could happen is someone steals it for what its worth in scrap.
    • dilios
      • Jul 2011
      • 29
      Yeah, just figured out the code. I was not looking at the right place in my service manual.
      What does this code refer to in itb assembly?
      I know people would not resist commenting on the machine! lol
      • Brian8506
        • 1665
        I would start with the sensor but I think your drum could cause this too.
        • dilios
          • Jul 2011
          • 29
          Really? How can I "test" the drum for failure? Also, should the belt be a bit loose on the assembly of be tight? should you be able to move it by hand?
          • Brian8506
            • 1665
            Maybe you should start by retracing your steps when you disassembled it and make sure everything is put back right, all sensors cleaned and everything connected.
            • dilios
              • Jul 2011
              • 29
              I had such a difficult time taking it out. Is it supposed to come out from the top or bottom? There is practically no room to wiggle it out of the bottom. Every time I do it, I'm afraid to brake it.
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5015
                Read PDF...................
                ir3100c-022.pdf
                • teckat
                  • 16083
                  [ATTACH]14774[/ATTACH]
                  [ATTACH]14775[/ATTACH]
                    You should be able to turn it by hand.
                    Check the white bushings on the primary transfer roller.If you have removed the two M4 screws these have a habbit of popping out of the recess in the transfer belt frame causing a slack belt.
