canon ir7105
  • NEOTECH
    • Dec 2010
    • 69
    [Misc] canon ir7105
    i dear i haveing problem in ir7105 finisher not detected. there is no code.
    how can i fix this problem plz help me i am to tide.
    thanks.
  • Herrmann
    • Jan 2006
    • 792
    Re: canon ir7105
    The finisher is connected via a coaxial cable with bnc connectors, make sure that it is not directly connected , you need the t-shaped connectors with the termination resistor attached to make it work correctly. Also make sure, that, after first install of finisher the mashine has done its full power down cycle (you will see it on the display, it tells you when to operate the main switch) otherwise it will not store the new settings/equipment.
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • teckat
      • 16083
      Re: canon ir7105
      SEE PDF-----TP06.pdf
      • davidj7
        • 1107
        Re: canon ir7105
        hello teckat i havent checked canon forums in a while . Good to see you are still here minus the pictures lol.
        a machine is only as good as your tech : source:screwtape ; the scary one
        • NEOTECH
          • Dec 2010
          • 69
          Re: canon ir7105
          hi dear,
          i did every thing coxail cable i ok but it will same problem not woking maybe there is reset how to reset function or limited function,
          if any one have idea plz give me solution. thank's
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Re: canon ir7105
            Use additional function to turn off limited function.Finisher must be turn on before copier!
            • NEOTECH
              • Dec 2010
              • 69
              Re: canon ir7105
              where is setting for turn off limited function?
              • teckat
                • 16083
                Re: canon ir7105
                do u have a message on the control panel that says Limited Function ??
                Is there a software version for the finisher displayed in service mode.
                Check if the dip switch bank on the finisher controller are in the 'OFF' position.
                If so change both switches to the 'ON' position and power cycling all components
                • spectraindo
                  • May 2008
                  • 313
                  Re: canon ir7105
                  Enter Service Mode :
                  COPIER > OPTION > ACCPST-D , if the finisher is properly connected then the display looks like this :
                  ACC1 FINISHER 00001001 01 < --- ENTER 1 THEN OK, RESET 2x.
                  SHUT DOWN THE MACHINE AND THE FINISHER, TURN ON THE FINISHER AND THE MACHINE.
