canon ir5570 e00821_002
  • hamdyyassin
    • 84
    please i need help with error 00821_002 in canon ir5570.
    thanksfor help.
  • Brian8506
    • 1664
    Re: canon ir5570 e00821_002
    This may help
    Error :
    The copier is displaying an error code of E821. It is noted that this error was not displayed; until removal and replacement of the AP kit.
    Workaround :
    In this case, the connections for the waste toner thermistor and the pre-exposure unit were mistakenly switched. Both connections are three pin connectors using two wires. They connect to J103A on the DC Controller. After the connections were reinstalled correctly, the copier began to function normally. When installing the AP kit make sure not to switch the two connections.
