iR Advanced 5045 - Black Toner Cover does not open
  • MFPTech
    • 486
    Brand New machine, installed the toner cartridges but the machine thinks there is no Black toner. The cover does not open either.
    Any ideas please?
    Thanks in advance
  • aodtech
    • 194
    Re: iR Advanced 5045 - Black Toner Cover does not open
    If the machine thinks that the toner is empty, then it should prompt you to replace it and you should have the option on the screen for the door to open. Is that not the case? Otherwise go into Level 2 so you have the option to open the toner doors from Settings/Registration. I all else fails, take off the rear cover and use the ratchet to manually crank the toner doors open.
    • MFPTech
      • 486
      I follow the options on the screen but the toner door does not open. I will try Level 2 or remove the rear cover. Thanks aodtech!
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5002
        In Service Mode Level 2 make the following change. COPIER>OPTION>DSPLY-SW> T-CRG-SW. Set T-CRG-SW to a 1.
        Exit Service Mode and perform the following:
        In User Mode, enter SETTINGS AND REGISTRATION> ADJUSTMENTS/MAINTENANCE> MAINTENANCE> REPLACE SPECIFIED TONER.
        • sx633
          • Sep 2011
          • 49
          There are Two different toner tubes for the IR adv 50xx range. If you or a customer has tried to force the wrong one in it will push back Two white hooks visible at the very end of the toner tube holder. Take the toner tube out and look inside with a torch. If you have reasonably thin arms you can just about reach inside and pull the hooks towards you. Then fit the correct toner.
            • 2621
            Any ideas please?
            Thanks in advance
            Unboxed machines can be a bit quirky, I have had this problem in the workshop. This method solves it.
            Take all the toners out using service mode as others have stated.
            Using a screwdriver you can push the latch in and close the toner covers.
            Turn the machine off and on.
            The machine prompts you to insert the toners dont !
            After a few minutes you will hear the toner motors turning and the message 'wait a while' appears.
            When the motors stop turning and the 'wait a while' message has gone put the toners in.
            • MFPTech
              • 486
              Managed to remove the Bk toner cartridge by removing the rear cover ....
              Then, I noticed that the Bk Toner Hopper had the top plate in the back hanging in a vertical position. Flipped it to horizontal position using a spring-hook and the problem got fixed.
              Thanks all for the replies!
              • zoraldinho
                • Mar 2008
                • 5002
                • buboy2222
                  • Aug 2017
                  • 13
                  sir how to go into service mode lvl2?
                  • guitar9199
                    • Sep 2016
                    • 1099
                    Instructions are on page 681 of the Service Manual.
                    • Afivmd78
                      • Feb 2021
                      • 11
                      Can you please tell me which plate you talking about, for me the issue is when i try to remove toner from service mode for yellow and black the door is opening but the toner stuck in there, cant remove it, and error comes E00025 0110, E00025 0410, it will go when we clear the error from service mode, but the issue is when i we want to change the toner we have to remove the back cover and use the wrench to remove it. Magenta and cyan toner removal process is working well. Can you please suggest me a fix for that.
