PC745- How to remove the bed glass to clean bottom side?
  • burchis
    [Misc] PC745- How to remove the bed glass to clean bottom side?
    I have spots on my glass that will not clean off. I tried using a razor blade but still no luck. I must assume that the spots are on the underneath side of the glass. How can I remove the glass for cleaning or get access to this side?
    Thanks.
  • Tec1
    • Dec 2011
    • 48
    Re: PC745- How to remove the bed glass to clean bottom side?
    take off all covers and control panel
    then you will see how glass comes off
    • burchis
      Will all covers come off by removing visible screws, or is there any hidden snap tabs to be concerned about?
      • Tec1
        • Dec 2011
        • 48
        i believe left side lower cover needs to be popped off with little tweeker.
        little holes in cover, put in driver and turn alittle
        note: sometimes you break tabs to get cover/covers off on some machines
