Firmware issue
+ More Options
Posts
  • Blues Guy
    • Aug 2009
    • 216
    Firmware issue
    Hi guys,
    Just to clarified is iR3030 and iR3045 firmware version for DC Con are the same ?
    I have face the problem after I have upgrade the DC con firmware version on my iR3030 the machine will appear error code E110 & E733.
    When upgrading the firmware I have mistaken selected the model instead of iR3030 I have selected iR3045. I have try reload back the correct model but the machine still appear the error code. After replace another pc DC con p.c.b from another machine the machine works back. I assume the firmware was not correct during I upgrade it. How to resolve these and is the firmware for both model same ?
  • teckat
    • 16083
    Re: Firmware issue
    Originally posted by Blues Guy
    Hi guys,
    there used to be a e733 Flash Dimm issue on the imageRUNNER 4570 / 3570 / 2870 / 2270 / 3530 / 2830 / 2230 -series printers when u flashed DCon/ don't recall issue on your series
    DCON is the same for 3030 & 3045
    if u have the "ALL" still listed -select it to re-write all firmware
    if u have newer SST > use the Start Assist Mode to re-write all
    see pub-----TP09_396a.pdf
    System Software v31.01.02
    BootROM v12.44
    Language v31.01 (JEFIG)*
    RUI v20.09 (JEFIG)*
    MEAP Cont v31.02
    Pre Install App v2.50
    SDL v1.10.1
    SSO v3.4.1
    Portal Service v2.1.1
    Security Agent v2.0.1
    DCON v5.01=== [iR3030/3035/3045]
    DCON v5.02==== [iR3025]
    RCON v13.02
    • teckat
      • 16083
      Re: Firmware issue
      SST Assist Mode
      Assist Mode:READ-----
      • Blues Guy
        • Aug 2009
        • 216
        Re: Firmware issue
        Thank you for your information Mr. Teckat,
        Another question I would like to check out is do you think if I were to follow the step to flash again the firmware to the problem machine will solve the problem error code. I mean the D.C controller P.C.B will back to normal ?
        • teckat
          • 16083
          Re: Firmware issue
          in the Assist mode, just select Overwrite All
          • Blues Guy
            • Aug 2009
            • 216
            Re: Firmware issue
            Thank you Mr. Teckat
            After flash the firmware again machine back to normal no more error code
            • teckat
              • 16083
              Re: Firmware issue
