iRAC 2020 Printing issue
  • HK James
    • Jul 2025
    We use iRAC 2020 printing some document VS iR 3320i print out
    We find out iRAC 2020 type font too light same as under toner/toner density not enough .
    i try use service mode adj Toner level
    i try Admin mode adjustment density level
    I try adjustment printer driver contrast
    No any improvement
    How can i fix this issue? please advice
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: iRAC 2020 Printing issue
    Is density OK with copying?
    Printer driver model?
    Do you have reader installed?
    • errorau
      • May 2011
      • 4
      toner saver mode is off???
      • teckat
        • 16083
        No any improvement
        u are trying to compare a iRAC Color printer to a iR Black & White Printer ??
        there is a Calibration procedure that needs to be followed on ADVANCED printers-
        When printing at 1200 dpi the default behavior of the IR is to make a prediction based on results from 600 dpi gradation control. To resolve this you must perform an Auto Gradation Adjustment for 1200 dpi and then another for 600 dpi.
        To display this option please make the following adjustment in service mode level 1:
        COPIER > OPTION > DSPLY-SW > HPFL-DSP > 2.
        Then perform both of the following steps:
        1. Additional Functions > Adjustment/Maintenance > Adjust Image Quality > Auto Adjust Gradation > For Printer 1200 dpi > Adjust
        2. Additional Functions > Adjustment/Maintenance > Adjust Image Quality > Auto Adjust Gradation > Standard > Full Adjust
        Once this is done, the output of 1200 dpi prints should be improved as expected.
        • HK James
          Thank All use service mode problem is fixed
          • teckat
            • 16083
            what service mode problem how fix
