ir3170 power on error
  • padstar
    Hi, I've got a grumpy ir3170
    Which shows an error on power up... It comes before the screen starts...
    It's a very lowlevel fault, but is starting 2 happen more often (powering it off for
    A while normaly fixes it
    The code on the screen is E0748-4043
    Any help would be appreciated
    Pad
  • teckat
    • 16083
    Re: ir3170 power on error
    Pad
    E748 //communication problem with the Main Controller PCB.
    First try removing and re-seating all connectors to the Main Controller P.C.B.
    sub-code not listed- but those E748 codes are- this procedure has helped many a tech save money and wasted time
    also follow the procedures in this pub>TP07.pdf
    • mjarbar
      Whilst you have the back of the machine off it is woth giving it a blow out as well, these pieces of junk somehow manage to get toner and paperdust where it don't belong and a build up of crud on the connectors cause all sorts of problems.
      • teckat
        • 16083
        hope u don't mean CAN AIR > that's a no no
        • mjarbar
          Not a chance, I would like to go home that night, no I use a vac and a brush (I use a 1in soft bristle paint brush) and just go carefully and lightly.
          Any connectors on the boards I give a wipe with IPA and a lint free cloth.
          Like I say these machines are a P.I.T.A. from start to finish and you have to go carefull with them.
