ir c3200 c1 problem
  • finestwine
    • 15
    ir c3200 c1 problem
    Hello tech.
    Feel free to email me with any advice at jermaine202@hotmail.com.
    Thanks for your help.
    hi5 - finestwine's Photos
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    check the cable from the c1 to the machine. It should be a crossover cable not a regular cable. Also I believe that the cable has to be in a certain plug. If it does not come up try switching the plugs and retrying the machine. Once you select the printer status then the machine will take a few minutes ( about 4 ) to get to the next screen. There may be a service code that needs to be set but I can not find it right now.
    • finestwine
      • 15
      thanks but i try many other cable but no luck still.
      • lkrsardis
        • Dec 2007
        • 316
        c1
        Try this. Get into service mode that it "* 28 *" .
        The menu should say BODY FEEDER SORTER, select BODY.
        Select OPTION.
        Select INT-FACE.
        Select IMG-CONT and set it to 3.
        Cycle the machine off an on with the main power sw.
        Good luck.
        Like the United States Postal Service It's a miracle it works!
        • finestwine
          • 15
          sorry that didn't work man.
          • markthebozo
            * = Additional Functions Button, not actual * key.
            • lkrsardis
              • Dec 2007
              • 316
              c3200
              oh well.
              • yourownfree
                • Dec 2007
                • 474
                c boot rom for c1
                make sure you have a "c" boot rom do as Ikrsardis said and Mr spock with crossover cable, turn the c1 on on the side ethernet in on the top, ethernet to the copier the bottom one. press the arrow on the copier screen it will say wait, guess you saw that part. version 1.1.1 huh? version 1.2 is out and better. 1.1.1 has problems.
                • finestwine
                  • 15
                  yea its a "c" boot rom. i even try changing the hard drive from a working one today, but no luck again.
                  do you have any other idea?
                  thanks a lot for all of you guys help.
                  • yourownfree
                    • Dec 2007
                    • 474
                    i think i know
                    do you have the IF/pcb installed ? You need that to make it work? Whoever you got it from needs to remove the iF/pcb from their machine and give it to you, since it is part of the c1 install kit.
                    • finestwine
                      • 15
                      I finally got it working. Thanks to Keith a.k.a lkrsardis, you really are a life saver. He gave me a newer software and instruction to install it.
                      • violeta
                        I am having the same problem with the server. Can you tell me how did you fix it?
                        Thank you!
