IR9070 - Ubuntu !
  • Smiley27
    • Apr 2011
    • 160
    IR9070 - Ubuntu !
    Hello! I am running Ubuntu 11.10 - 32 bit - and printer on my network is IR9070 ( office ) , I have never used Ubuntu before, so I wonder if there is driver for this? I seached all over but even when I found it, I had no skill to install it..
    Suggestions?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IR9070 - Ubuntu !
    imageRUNNER ADVANCE C9070 PRO
    select linux OS and language..
      Download the Linux file from the link provided, extract the file and use Ubuntu software center to install the .deb file.
      If the software center says something like xxx depends on yyy this means the driver needs other packages installed first. These are called dependencies and are a bit like .dll files in Windows.
      Good luck.
