E000355_0003
  • nochick
    • Jan 2012
    • 80
    [Error Code] E000355_0003
    Hello
    iR6570 code E000355_0003 after re plug on PCB
    some of my friends in overhaul department said I have to re install firmware and bring battery out of PCB and reinstall new FRAM COUNTER too.
    Is it true it's a lock from factory that ir5570/6570 produce for use only 1 million meter after that if reinstall PCB then code 000355 come.
    and after 5 millions there will be another code to lock machine.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: E000355_0003
    the Counter Memory, Serial Number and MainController PCBs work as a set and are considered the “Soft Counter Circuit”. The Counter Memory PCB is
    electronically stamped with the serial number from the Serial Number PCB. Neither the Counter Memory
    PCB nor the Serial Number PCB can be swapped to other equipment. The Counter Memory PCB keeps track
    of the total count, which cannot be erased or changed. The service counters are retained by the Main
    Controller. These counters can be reset manually through service mode. When the Counter Memory PCB
    must be replaced, after installing the new one, the new Counter Memory PCB learns the Total Count from the
    Main Controller. This is retained in SRAM on the Main Controller PCB and held active by means of an on
    board battery.
    It is illegal to tamper with this circuit in an attempt to falsify the counter readings of any Canon
    Copier.
    As mentioned in previous Technical Publications, the Counter Memory PCB is a matched board with
    the Serial Number PCB and cannot be swapped with one from any other equipment. Doing so may
    change the error code and will not correct the problem and will certainly add to confusion, thus
    increasing downtime.
    Never replace two boards in the Soft Counter circuit at the same time! This would include any
    two of either the Counter Memory PCB, Main Controller PCB (or Image Processor depending on
    model) and Serial Number PCB (see Figure 1). Doing so may change the symptom to an E355 code
    or E354 code, which would be unclearable.
    In some cases, after replacing the Counter Memory PCB, an E354 or E355 code may appear. At this
    point, enter Service Mode and access the “Clear” tab under “Function” mode
    (FUNCTION>CLEAR>E355-CLR).
    IR 6570 in my shop have 2,2 million and work normally.
    • vigour
      • Aug 2010
      • 1038
      Re: E000355_0003
      Originally posted by nochick
      Hello
      Not true. I have seen many over 1 million
      IR 105 is the only one I know which shuts down at 20 million , then you have to change some boards to continue for another 20 million
      • nochick
        • Jan 2012
        • 80
        Re: E000355_0003
        zoraldinho, thank you very much
        I didn't know it before.
        This info could help a lot.
        by the way I use to see iR8500 11 million meter and surprising that it's still running.
        • zoraldinho
          • Mar 2008
          • 5015
          Re: E000355_0003
          • ts-lx
            • May 2011
            • 59
            Re: E000355_0003
