Canon C5180 - Cyan Dropping out of copies?? See Attached PLEASE
  • Dave Braman
    • Mar 2011
    • 16
    pg-10.jpgAuto G 5180.jpgBeen working on this Canon C5180. It was all set for a while, Now the Cyan is dropping out on copies in random areas.Tried New Drum, New Toner, All ITB Cleaning and adjustments etc... Please look at the Auto Gradation sheet this is printing. You can see the Cyan Trouble. Any Thoughts? Greatly appreciated.ThanksDave
    • 16083
    Re: Canon C5180 - Cyan Dropping out of copies?? See Attached PLEASE
    Dave
    post a pg10 test print
    & a single PG5 for CYAN at 255 output
    remove side cover over Manual Feed> to view ITB when doing these test prints> observe lay down on ITB
    check Drum ground tab position- Check and clean the drum ground tab located inside the front drum access cover.
    • Dave Braman
      • Mar 2011
      • 16
      [QUOTE=teckat;281344]post a pg10 test print
      3200.jpgSeems to come and go so perhaps the Drum ground tab will do just that?
        • 16083
        [QUOTE=Dave Braman;281364]
        [ATTACH=CONFIG]14904[/ATTACH]Seems to come and go so perhaps the Drum ground tab will do just that?
        seeing that PG10/ U need to check your CYAN primary charge roller position inside the ITB unit/
        make sure the end shaft is locked in the black plastic tab/spring loaded catch and is not damaged
        • Dave Braman
          • Mar 2011
          • 16
          [QUOTE=teckat;281374][QUOTE=Dave Braman;281364]
          ITB.JPG[Tried all these procedures.... Still happening? Even tried a completely different ITB assembly from another machine....Same Thing? Could it be the cyan laser?
            • 16083
            [QUOTE=Dave Braman;290922][QUOTE=teckat;281374]
            [ATTACH=CONFIG]14906[/ATTACH][Tried all these procedures.... Still happening? Even tried a completely different ITB assembly from another machine....Same Thing? Could it be the cyan laser?
            don't think it's a Laser issue. u can swap lasers to test/
            post a pg5 solid single CYAN page
            • Dave Braman
              • Mar 2011
              • 16
              Here is a PG5 Cyan Printout.
              • Dave Braman
                • Mar 2011
                • 16
                This is an auto Gradation (all 3 Test Prints) all Cyan. Perhaps someone has seen this before??? Any Help would be appreciated.
                  • 16083
                  Laser is good.
                  WHAT ARE THE #'s for
                  auto gradation adjustment target value
                  COPIER>ADJUST>PASCAL>OFST-P-Y,M,C,K
                  COPIER > ADJUST > PASCAL > OFSE-P-C
                  have u check your P -PRINT settings against the Original P Print settings sheet ??
                  • Dave Braman
                    • Mar 2011
                    • 16
                    The pascal Cyan setting is -2
                    Same as the previous P-Print
                      • 16083
                      swap the laser
                      • Dave Braman
                        • Mar 2011
                        • 16
                        OK....I Swapped the Laser. NO CHANGE..
                        Printed out a New Cyan PG-5.
                        Notice the top Drops out approx 1/8 of an inch AND Then it is Darker at the top and slightly fades light as you go to the bottom of the printout?
                        WOW... This is driving me Crazy!!!!
                        Somekind of communication problem I suspect???
                        Dave
                        What would you do next?
                          • 16083
                          Dave
                          Remove small side cover to view ITB>run the PG5 CYAN> look at ITB SHEET>is the image fade off visible on sheet ??
                          if so> remove ITB & ITB SHEET> inspect that CYAN Primary charging roller position> sometimes they look level> have u replaced this roller before ??
                          if pg5 cyan image is solid on ITB> before separation>suspect the HVT 1 for Cyan or swap connectors with another color--
                          if fade is after separation >suspect the HVT 2
                          • vigour
                            • Aug 2010
                            • 1038
                            At some point you need to swap the lasers back or swap the values for both colours,
                            The values are also written on each laser.
                            • Dave Braman
                              • Mar 2011
                              • 16
                              I re-set the values in for the "New" Laser. I have another machine I use for Parts so I just put one of those in. Thanks!
                              Anyone have the Replacement Procedure for HVT1 and or HVT2??
