e0070102
  • roybee
    • Mar 2012
    • 5
    [Error Code] e0070102
    have error e0070102 1hr after fitting new fuser to irc4580i.fixing belts look central and unable to get into service mode before error appears
  • teckat
    • 16083
    Re: e0070102
    The service mode items [FX-UHP-S] and [FX-LHP-S] are the mode executed only during installation or after replacement of the fixing assembly. If they are executed in the other timing, a negative effect could occur.
    DID U DO THIS ???????????????????
    After turning the power "On" and the machine comes to a "Ready" state, the following adjustment needs to be performed to prevent the E007 code.
    Adjustment of Fixing Assembly:
    1) Enter the Service mode. Select COPIER > FUNCTION > FIXING > FX-UHP-S > OK
    2) Check that 'FX-UHP-S is OK. This will take approximately 5 minutes.
    3) Enter the Service mode. Select COPIER > FUNCTION > FIXING > FX-LHP-S > OK
    4) Check that 'FX- LHP -S is OK. This will take approximately 5 minutes.
    Check that the tension spring for the pressure belt HP sensor flag is in the correct position. Verify with photos below.
    Incorrect installation.
    shown below
    DRAFT.JPG Correct installation.shown below new.JPG also read this PDF----E007 Fix Procedure.pdf this pdf may help
