IR2270 rdf misreads paper size
  • repeatcopiers
    • Sep 2008
    • 591
    I have an IR2270 in the field that the feeder reads letter size paper fine but if you put a Letter R or Legal sheet in, it asks for 11x17 paper. I know I've seen this in the past but cannot recall what the fix was......thanks for any help you can offer.
  • vigour
    • Aug 2010
    • 1038
    Re: IR2270 rdf misreads paper size
    do the width adjustments. If that does not work you need a new VR
    • linuxxpwin
      • May 2008
      • 205
      I agree with vigour, however before you change VR, please check your paper size sensing sensors, as I have had that problem before, a sensor was bad and another with the sensor flag broken and missing.
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        sevice mode> Feeder>Function
        Put an A4 on the feeder and select TRY-A4 then OK
        Put A5R and select TRY-A5R and then OK
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
