Canon Ir7105 Finisher V1 - various error codes
  • maverick911
    [Error Code] Canon Ir7105 Finisher V1 - various error codes
    Hi everyone, This is my first post and I'm hoping someone can help. We have a V1 finisher that is displaying various error codes.
    E568-8001 fault in transport roller HP sensor or transport roller shift motor
    E566-8001 fault in horizontal registration sensor or horizontal registration detection unit shift motor
    E540-8001 - fault in tray A lift motor or finisher controller PCB - tray A rotation sensor
    We thought the common cause to all three errors was the Finisher Controller PCB, We verified by trying the board in a working finisher. We got an immediate E540-8001 so we had a new board overnighted. When the new board was installed we got an eeprom error since the new board didn't have an eeprom installed on it. We took the eeprom off the old board and went right back to an E566-8001 error.
    Can the eeprom be the cause of our problems or are we barking up the wrong tree.
    Thanks in advance for any help.
  • teckat
    • 16083
    Re: Canon Ir7105 Finisher V1 - various error codes
    did u try the board from the working printer/finisher in the problem finisher
    • vigour
      • Aug 2010
      • 1038
      Motors on that finisher often go bad, and some of them BLOW the boards (e.g Motor Driver), so tred carefully.
      I have had to replace that horizontal motor, so it is a likely candidate.
      • watson
        • Sep 2009
        • 64
        Agree w/Vigour, the motor blows a pico fuse on the driver bd. Repl motor before bd or you will blow the fuse again.
