IR 5570 - Blank Copies Using ADF
  • suryaabadi.72
    • May 2025
    [Misc] IR 5570 - Blank Copies Using ADF
    Hi All,
    I have iR 5570 machine with the ADF.
    Sometimes when i want to make copies from the ADF, the papers that come out are BLANKS.
    I have tried replacing with another ADF, and it still does the same thing.
    Have anyone experienced this problem?
    Thank you in advance.
    • 16083
    Re: IR 5570 - Blank Copies Using ADF
    Originally posted by suryaabadi.72
    Hi All,
    what do u mean sometimes
    check your READER cable & Reader pcb
    User presets and mailboxes maybe lost after performing the MMI Clear.
    To perform an MMI clear enter service mode and perform the following. Select Copier > Function > Clear > MMI > 'Ok' and then power cycle the machine.
    • suryaabadi.72
      Hi teckat,
      Thank you for the reply.
      When i mean sometimes, it sometimes works properly and sometimes does not.
      more often, it does not.
      I have tried replacing the Reader PCB and clean the Reader cable flat, but still no luck.
      Also with the MMI Clearing.
      Ps: My DADF does not look like the attached picture. I believe yours is IR 5055 or IR 5075, which is the newer version of iR 5570.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5000
        Did you make a print tests also,to be shore about the reader?
        • nizam
          • Mar 2011
          • 40
          Tray width
          • zoraldinho
            • Mar 2008
            • 5000
            Originally posted by nizam
            Tray width
            Sometimes??
            • Van Steal
              • 177
              Tray width
              My money is on the user placing paper on far right sensor flag (a3 detechtion sensor) when copying a4. Took me several visits to a customer before they finally did it before my eyes
