IR3300 dark/light adj
  • repeatcopiers
    • Sep 2008
    • 591
    I have had several IR3300 where the light/ dark adjustment doesn't make any difference, is there something I can do?
  • teckat
    • 16083
    Re: IR3300 dark/light adj
    u mean the CONTRAST DIAL for LCD
    do u have a working LCD / DOES PRINTER POWER UP WITH GREEN LIGHT
    Clean/Re-Seat Memory DIMM> ends
    Re-seat connector J122 on the composite power supply. If this does not correct the problem, try cutting the wire ties on the harness from connector J122 on the composite power supply to connector J1058 on the main controller.
    • repeatcopiers
      • Sep 2008
      • 591
      Sorry I wasnt very clear at all. When the customer wants to lighten or darken their copy, the exposure adjustment doesn't make any difference when they try to darken or lighten the copy. The screen lets you do it but the copy comes out the same, regardless of how dark or light you make it.
      • teckat
        • 16083
        try another panel ? to isolate issue --
        • santosh_potdar
          try *28* then adjust and then DENS to 2 press ok and then restart machin...
