Measure Against Error Code E542-8002 / E500-0001 / E5F1-8000 / Jam Code 1320-REVISED
  • teckat
    • 16083
    [Error Code] Measure Against Error Code E542-8002 / E500-0001 / E5F1-8000 / Jam Code 1320-REVISED
    Measure Against Error Code -
    Proper Sensor handling information-
    Products Affected: Serial Numbers Affected:
    Finisher-V1--TBD
    Saddle Finisher-V2--TBD
    Finisher-AB1--TBD
    Saddle Finisher-AB2--TBD
    Finisher-AF1--TBD
    Saddle Finisher-AF2--TBD
    Staple Finisher-F1 PRO--TBD
    Booklet Finisher-F1 PRO--TBD
    see pdf----------
  • markdmt
    • 76
    Re: Measure Against Error Code E542-8002 / E500-0001 / E5F1-8000 / Jam Code 1320-REVI
    how often is it the finisher control PCB? I had a tray hang up on the cover after being moved and stopped the tray from moving. I think motor, and sensor are fine just not moving and showing finisher unusable on the screen.
    • vamoursly
      • Sep 2011
      • 273
      Hello
      I have a Canon Y2 Saddle finisher with error code E542-8002, does the TP apply as well?
      I only get the error when printing or copying to delivery tray B
      I bought a SM for it;
      Code Detail Error Description Detection timing
      E542 8001 Tray 2 shift motor
      (M108)/Tray 2
      shift area sensor
      PCB
      If the tray does not return to home position when
      the tray 2 shift motor is driven for 20 seconds.
      If the tray does not move to other area when tray
      2 shift motor is driven for 4 seconds.
      8002 When reached to the upper limit area before the
      paper surface sensor detects paper surface during
      the paper surface detection operation.
      • Zela
        • Mar 2014
        • 25
        I have a problem with jam 1320, sensors FM2-4254 I checked and tried in another finisher and they are OK.
        But in mine after warming up the machine will appear again.
        It occurs to me only PCB.
        Does anyone have any idea?
        Thank you
        iPRc6000VP, Saddle Finisher AB2
        • teckat
          • 16083
          Originally posted by vamoursly
          Hello
          (M108)/Tray 2
          shift area sensor
          PCB
          I would take off both covers to inspect flags ( shaft breaks/cracks> gives false impression that flag blocks sensor correctly >
          known issue on these finishers
          Check to be sure that the Paper Surface Sensor Flag is not stuck behind the finisher cover.
          they should rock back & forth easily
          • Zela
            • Mar 2014
            • 25
            Finisher AB2 does not flag the output.
            But I figured it out ....
            They were dusty reflectors on the sensor UN24, which is before output.
            • teckat
              • 16083
              I was posting a reply response to vamoursly on Canon Y2 Saddle finisher with error code E542-8002/
              no on your issue------
              • lilleputte
                • Jan 2013
                • 153
                Thanks for this info
                /lilleputte
                • teckat
                  • 16083
                  /lilleputte
                  Welcome
                  Best support site in town :-))
